Flywheel differances ??
ukmember
Hi,
having found the problem with the 30hp rude and ordered the new cdi from your side of the pond, i have a dilema regarding the flywheel............... the underside of the one on the boat is heavily scored from the damage caused by the cdi falling apart, i have a spare one that is the same dimensions etc but is factory painted, where as the original is not.
Now can i remove the paint from the factory painted one to use as a good one or should try the original first.
Regards
UK Member
