TheRealTeeHill
- May 5, 2013
- 13
Hello All,
I am in the process of stripping and servicing my twin sea horse and have got to the flywheel/magneto... I have a harmonic puller but the bolts supplied, 1/4" and 5/16" are too big (and probably too weak). I understand that I need grade 8 bolts for the strength but what diameter, length and TPI? I have measured the inside diameter of the holes and they are around 5mm, don't know if this helps at all?
The part I am looking at is #5 (Part # 0582388) on this diagram and it is the three holes on top around the crank shaft hole that I need to size bolts for.
Thanks in advance, Tee.
