flywheel question 2000 40hp merc
dcunningham
should the gear on the starter (bendix) be locked into the flywheel when motor is off? Most I've seen are only locked to start then fall below.
Any help would be great
DEREK
Barnacle_Bill
Re: flywheel question 2000 40hp merc
No it shouldn't. It should drop down when the starter is not running. The shaft the bendix rides up and down on probably needs cleaned and lubed.
