flywheel questions
bayliner09
do i need to have my flywheel reserficed on my 78 aq120b or can i just sand all the rust off and add the anti seize and where do i need to put the anti seize on the flywheel could some one help
Re: flywheel questions
Nope,... No need to resurface,...
Clutch chatter ain't much of a problem in boats...
Donno,... Why would ya want to...
bayliner09
thats what the manual says it says aply anti seize to fly wheel before instalation
billbayliner
My guess would be that the manual (probably not an OEM) wants the crankshaft flange and the mounting bolts lightly coated.
They probably also want the drive coupler bolts lightly coated.
These are areas where the automotive anti-seize may be OK to use.
Remember to NOT use the automotive anti-seize on anything below the water line.... engine parts only.
