I have a 1977 Chrysler 10hp that has a stubborn flywheel. I have tried a gear puller to no avail. Any suggestion?<br /><br />Thanks for you consideration.<br /><br />Andy
I don't know what kind of puller you're using but if the flywheel has drilled and tapped holes (3 or 4)in the top of it, a crows foot puller and a 1/2" air impact wrench will do the deed.<br /><br />c/6<br /><br />Hooty
Do a search using "Flywheel removal" You'll find at least 30 posts dealing with this topic in great detail. You'll also learn that you never use a gear puller on a flywheel....
