Flywheel repair
Rampant Johnny
Hi,
I have a 1992 60HP outboard with 4 teeth substantially gone and was wondering how to effect a repair. (This particular item is very difficult to source and I am in new Zealand where there are even fewer). Any tips on reconstituting the teeth? (I already posted this question in an old forum as I didn't quite understand how the system works. Oops.)
Thanks
gm280
:welcome: Rampant Johnny, great to have you join us here on iboats.
Unless you know of a great welder that could literally weld on material to cut the missing teeth, I don't see any other option. But then I most certainly would have it balance it as well then. A spinning flywheel going 5000 RPMs can seriously cause some real problem if the teeth came off or was out of balance... IMHO!
Bosunsmate
try blenheim outboard dismantlers, they are the biggest i know of here in NZ
failing that try the guy at kamo outboards, he knows a thing or too about parts
Rampant Johnny
Thanks. I suspected that a repair might not work, sadly. I have approached marlborough outboard dismantlers but with no joy so far. Yes the flywheel pictured on ebay lookd like it would work but the listing has closed. I will keep looking.
