clutch dog
- Jun 16, 2009
- 11
I have a 115 mariner 1985 if i take the flywheel off to but a new stator on do i have to reset the timing.
J Martin, if you change from an 8 pole to a 12 pole stator or from a Merc to a Mallory or CDI the position of the mounting screws and the size and position of the stator coils can affect the location of the trigger relative to the old stator. That will change the timing. The recommendation for checking TDC and adjusting the pointer is in every manual including the Merc shop manual. Heck, it's even recommended as part of the basic Link and Synch process.
Hey John, I played with a couple of different triggers and stators on a 115 that I'm re-building. You're right it doesn't make any difference as long as nobody futz'd with the pointer everything else should be fine.
Rod bearing wear and loose magnets can change the timing but if they're sloppy enough to change the timing the engine has other problems that need to be addressed.
Sorry for the ping.
