flywheel
patmilstead
Want to use back mounted starter need 14 inch 168 tooth with ring on front flywheel.
Does any one know where I can get one or what has to be done to existing one.
Thanks
Pat
:confused:
Re: flywheel
Thanks
Pat
:confused:
Ayuh,.... Just knock the ring gear off the flywheel ya got, 'n install it on the other side of the flywheel...
Capt Ken
Re: flywheel
Flywheels are the same. Due to the ridge that the ring gear rides against, it can only go one way.
Lyle29464
Re: flywheel
depend on the brand of engine and who made the flywheel cover.
If your starter was on the front side the flywheel could be too small. On some of the oddball stuff the same flywheel was used. On most setups you did need a larger flywheel and the gear had to be on the back of it. What are you working on? what block/ what cover?
patmilstead
Re: flywheel
Chevy 350 engine , it has 14 inch plate 168 tooth not cut down on opposite side to fit ring gear.
GM bellhousing for velvet drive 71c. It starts and runs ok. Starter is exstremly hard to get to stringer is in the way.
I have to partially pull motor to change stater.
The Gm bellhousing has opening for back mount in top right hand area.
Pat
Lyle29464
Re: flywheel
I just put a 350 in my 17. used the 168 but the ring gear is on the back side. It is a mercruser flywheel cover.
