Hello everybody...I am new around here, but I promise that, unlike most newbies, I read much of what is on these forums before I started asking questions
<br /><br />Now, the question. If you put foam in under the floor and don't let it contact the flooring, then don't you create at least a small void for water (even if it is just condensation) to collect and cause the bottom of the plywood to rot?<br /><br />Conversely, if you do let the foam contact the bottom of the flooring (and assuming that you allowed for expansion and didn't blow the whole thing up), then how hard would it be to get the flooring up if you ever had to? I know that the foam isn't all that strong, but we are talking about a LOT of square inches of foam holding the floor down.<br /><br />Just my $0.02 worth,<br />Joe
