Re: Foam..Important?? keep or remove
I did replace the foam in mine, I noticed there were 4 main stringers, but only 2 tranverse bulkheads, one at each end of the gas tank compartment, so to me it seemed needed for stiffness.
I wonder if you had replaced the stringers using epoxy, which is supposed to be way more waterproof than poly, you would be less likely to have an issue down the road.
The way my boat was orginally, it lasted about 15 years before the rot got bad, and I have no idea how the past owners took care of it.
Now it has good covers, and a deck with no carpet, and all the holes drilled for seats and such were sealed with 4200, so I figure it should last long enough, I didn't want to regret not putting the foam in for safety reasons.
