Foam in a can?
NathanY
How good is this stuff for floatation? I use it in all my jon boats to fill bench seats so the foam this is already inside does not move, but how good is this stuff?
mellowyellow
Re: Foam in a can?
howdy Nate,<br />never used it on a boat, but have used it in<br />my basement where its real damp. doesn't appear<br />to wick moisture at all.... even after 5+yrs.<br />have no idea about bouyancy but gotta be<br />better than nothin'.<br />M.Y.
MrBill
Re: Foam in a can?
There are several different types of foam. In the last few years the manufacturers of the household type have reduced the expansion rates of their foam, we used to be able to get a alot more "mileage" out of a can.<br /><br />Most of the foams break down and dry out significantly when exposed to sunlight (UV exposure is the issue). For floatation without exposure to sunlight you'll need a closed cell foam. If your expectation is to expose it to sunlight...you will need a specialty foam.<br /><br />To answer your question...How good are these products? They are excellent if matched appropriately to the intended use. Do not expect the Home Depot can of foam intended for wall cavities, in dry conditions, not exposed to sunlight to perform well when exposed to sunlight and exterior marine conditions.
