Just started my first restoration this month, transom, stringers, and floor along with cosmetic work. The Boat is a 15.5 TEMPEST trihull. I have run into a snag with the floatation foam, I don not know if it was not mixed properly at the factory but against the hull in in quite a few areas there is a residue that it looks like it crystallized and very hard. I have tried different scrapers and a wire brush and no luck. Would a wire brush on a 4.5 inch angle work or would it be to aggressive on the hull? Any suggestions would be gladly appreciated and thank you in advance for your ideas
