bobgritz
- Sep 22, 2009
- 185
In the past, I always sprayed a carburetor starting fluid (or spray bottle of mixed gas/oil) when trying to find a vacuum leak (RPMs would increase). I recently read a post that mentioned using 'foamy water' to detect vacuum leaks.
I imagine this would also cause a change in the rpm's (a drop in rpm's) but it might also have the advantage of 'bubbling' if it was sprayed onto an area of positive pressure seapage.
Hmmm, interesting! Anyone out there use foamy water to detect leaks in and around the carb, fuel pump, etc.?
