Foggin Question
BigPoppaG
In the owners manual it says while operating fog internal surfaces of engine by squirting 8 oz foggin oil into carburetor bores. the squirt 2 ox of fogging oil rapidly into carburetor until engine stalls. I fogged a outboard before and just squirted it into the carb. Whats the difference? Carb bores and Carb? :confused:
crazy charlie
Re: Foggin Question
There is no difference.I usually slowly pour a cup of marvel mystery oil into the carb as it is running until it stalls.The outboard because of gravity has to be sprayed to do it properly.Charlie
BigPoppaG
Re: Foggin Question
It says to shut off the gas flow and spray until the engine stalls itself from lack of gas. I have heard both ways of doing it. When I had my outboard. I sprayed until it stalled. Any difference between that and a I/O? Just want to make sure it's done right. ;)
crazy charlie
Re: Foggin Question
The principle is the same.To coat the internals witha film of oil.Some motors will be tough to stall with a spray of fogging oil.Sometimes you need to spray 2 cans at the same time.That may be the reason for shutting the fuel supply.On either the i/o or the outboard you can add removal of spark plugs and spray more fogging oil in each cylinder.Charlie
BigPoppaG
Re: Foggin Question
All ready do. Thanks for all your help Crazy Charlie. I have more questions but it took me a while to get through the past posts to see if there was any info I could use. See ya guys around.<br />BPG
crazy charlie
Re: Foggin Question
You are loaded with questions.You will love it here!!!! Welcome!!Charlie
summit1
Re: Foggin Question
I don't have any fogging oil, and someone told me I can use 30 weight oil instead. Is this true?
tommays
Re: Foggin Question
any oil will due the job st 30 is fine i just use and oil can and pump it in till i get a nice blue cloud<br /><br />tommays
deputydawg
Re: Foggin Question
I have been working farm equipment repair for years. We always fog the irrigation engines at the end of the season. Most of these engines were Ford or GM 6 cylinders, a few Chevy 454, and Alice Chalmers 6 cylinders. When I fog them I always used either engine oil or irrigation drip oil. Drip oil is the same as engine oil, just thinner. I had a dish soap bottle and usually would squeeze a squirt into the carb until it either smokes heavily or choked and died. A few engines I did not get a very heavy blue smoke, so I would crack a vacuum line and hook that to my bottle. This would suck oil into the engine. <br />The ideal situation to prevent corrosion would be to tear the enine apart and coat everything with heavy lithium greese. This would be overkill and the cost would be outragous.<br />You can get by witout fogging an engine, but it will last a lot longer if you do fog. The key is to get enough into the engine to make it smoke for 10 seconds or so. Second choice is put into cylinders and rotate engine.<br />In the spring I would sometimes take the distributor out and prime the oil pump before cranking. This is not necessary, but also helps reduce wear during the first 10 seconds of running.
summit1
Re: Foggin Question
Thanks for the help guys! Worked like a charm!
