fogging oil
bos22
What do you recommend as a fogging oil for my 30hp and 225 evinrude/johnson?
crazy charlie
Re: fogging oil
Any fogging oil will do just fine or you can use marvel mystery oil.The aerasol can that the fogging oil comes in just makes it so easy and it also foams up to get into spots that normally dont get lube protection.I used to pour a little Marvel into each spark plug hole and crank the motor before putting the plugs back in.This always worked fine until I saw the fogging oil was only 3 bucks a can. Charlie
Brew
Re: fogging oil
If you get the OMC/Bomb brand of "fogger" you can attach the aerosol can to your fuel system via a valve (looks like a bicycle tube valve)rather than spraying it directly into the carbs. It's certainly convenient and worth the extra buck or two to me.<br /><br />Cheers,<br /><br />Brew
