Fogging Question 1976 Merc 110
iliketrout
I rebuilt my carb and therefore there is no fuel left it in. I haven't reinstalled it on the motor yet as I just got the flange gasket. Fuel lines are all empty as well.
Question for winterizing - should I reinstall everything, fire it up and fog this way, or leave the fuel system apart and empty of fuel? I'm worried about corrosion in the fuel system but I wouldn't have to worry about fuel problems. I would only get the fogging oil on the cylinders this way...
Any tips from you veterans would be greatly appreciated! This will be my first winterization.
jerryjerry05
Re: Fogging Question 1976 Merc 110
If it's off you can spray through the front as you turn it over.Then into the plug holes.Anything you spray into the carb(WD-40) is gonna gunk up and dry.
Running stabilizer through the system would be what I'd do.
That way it's in the pump and carbs.Don't run the carb dryJ.
