fogging
voodoo
I fog my motor (with 1/4 can) whenever I leave the cottage.<br />This stuff is mineral oil and non polluting right??<br />I have seen motors rust up real quick and it makes me feel better knowing I'm not scraping rust off the walls and bearings every time I come up and start it.<br />Does anyone else do this too? Is it worth the aggravation and the looks from the cottagers?
voodoo
Re: fogging
Really? My thought was oil is cheap ,bearings ain't.<br />I am only up there about every 45 days and it sits in the water, does that change things?
rickdb1boat
Re: fogging
Dj is right about this. The left over oil in the cylinders will keep it lubed for quite a while. And it sounds like you use it fairly often. If it was to sit a few months between use, then I might consider fogging it, but then again, maybe not.
