Re: follow up pee hole question...
On your engine, check and see if there is a 1/8 inch pipe plug located at, or above the top cylinder on the starboard, or right side. You can screw in a nipple there. Personally, I would rather have a pressure guage, than an indicator stream. You should have a lot of water flow to those thermostat hoses.
