Just bought 1992 26ft Rinker Fiesta Vee 260. Changed the foot oil. Took boat out this weekend and when I went to flush and clean boat up I noticed noticed foot oil coming out of vent thing that you put muffs over to flush engine (not sure what these are called). Wasn't coming out fast just a slow trickle. Also noticed the foot oil leaking where the lower unit and upper unit are bolted together, where the meet. Its very slow leak as well. Thinking a seal or gasket might need to be replaced there. Does that sound like a possiblity? If Thats the case would it seep down from there and cause to come out of the vent thingys? I did unscrew the foot drain to see what oil looked like and it didn't look like there was any water in the oil.
Also trying to figure out how to identify what carb rebuild kit i need. Its a 5.7 mercruiser. Looked at carb. The only number I saw was "8822". No other numbers were on there.
