For those of you that use muffs for flushing
rick3452
This works great.....It will not slip off when you turn the water on and it may save your impeller or engine.. just slip on the muffs, line up the holes and insert rod through both holes...
Davem3
Re: For those of you that use muffs for flushing
hey, i like that idea, the rod is on the outside of motor, towards the prop side, right?
rick3452
sorry, not sure what you mean by the prop side. This will probably work on any outdrive or out board....
Texasmark
My muffs look just like that but the rod goes down through the center. It easily goes through the water pickup holes from one side to the other of the engine, engages the locking mechanism, hook the water up and wala..
Mark
Pony
I just use a vice grip to hold the muffs on. It stays completly out of the way of the prop for checking to make sure the motor is shifting properly.
Don S
Merc makes one.
attachment.php
