I just picked up my 92 bayliner with the force 120 from a local mechanic who is supposed to be "the best around". I took the boat to him to fix a high speed miss. When I arrived at his house his first question was has the boat ever ran. I told him yes and reminded him about telling me how he had ran the boat 2 days prior. He proceeded to tell me that the boat now would not even start. I was pretty mad so I just took it home. The first thing I did once at home was remove the flywheel and checked the key. Low and behold the key had sheared. After removing all the pieces I noticed that the keyway in the crankshaft was wallered out to the point that a new key would no longer locate the flywheel as it should. Has anyone else had this problem? Would you try welding the key way and reworking it with a die grinder? My dad and I both have a combined total of 60 years of machinists/ tool maker work. I just don't know what the tolerance is on the location of the key way. I really don't want to purchase a new/ used crank.
