There will either be three tapped holes in the top of the flywheel into which you thread three bolts and a puller modified for hoisting OR the inside hole of the flywheel will be threaded to accept a Mercury hoisting tool.
I made an "L" bracket and secured it under the flywheel nut, hole in one leg just fits over flywheel stud , other hole large enough to get hoist hook through.
