force 120 l-drive won't start
tmay3505
1991 force 120 replaced stator,flywheel.trigger,<br />coil packs and plug wires. engine tries to start but won't. any help greatly appreciated.
Kajun37
Re: force 120 l-drive won't start
as long as your getting spark on all 4...i'd look toward a fuel problem....have you tried using a starting fluid yet?<br /><br />a standard answer here is have you done a spark check...compression check yet?
tmay3505
thanks,<br /> i got it running. but i can't figure out where<br />the water from the water pump is suppose to come<br />out. I want to make sure it is coming out so i don't burn it up.
roscoe
Is there any water spraying out the exhaust relief holes on the back of the driveshaft housing?<br /><br />Most of the water will exit thru the exhaust.
