Crooked hook
- Jul 4, 2016
- 1
I have a force 120 motor that was running good. Right now the motor runs good at an idle, but once you open it up, it loads up and starts sputtering and, it only runs good for about 10 minutes. I already checked the timing and the spark, adjusted the floats, cleaned the carbs, checked the compression, and put new plugs in. What else could possibly be causing it to run like this?
