firestorm41
- Feb 26, 2003
- 6
ok heres the deal i have just purchased a 1990 bayliner cobra bass boat with a 120 force from a friend that has never had the boat in the water. he knew that the water pump needed to be replacedamond other things. i replaced the pump housing and impeller. at this point water flows wonderfully throught the two holes about mid way up an the back of the engine when the engine is at idle or low rpm. however when i get passed say 1500 rpm i don't see any water coming out at all. now i have consulted with many techs. on this problem and half of them say that there is a problem that it should be pumping water out those holes all the time and the other half says that once it gets up to speed it shoots all the water out the foot. i need some help deciding whether this thing is working right or not i have not run it enough to get a overheat warning for fear of damamging it. any ideas wuld be greatly appreciated thanks aaron
