force 120 wet white sludge on top two plugs
beam120
96 Force 120 recently pulled plugs. top two are wet with white oily substance. I'm assuming this is water?? also when I open her up I get about a 30 second hesitation. I'm going to replace the head gasket. will this fix the problem? :confused:
beam120
Re: force 120 wet white sludge on top two plugs
man, one of the head bolts is stripped, this is a used engine, that explains the leak! Do I need to tap new treads? I'm unfamiliar with outboard heads ? thanks
Hooty
You or a machine shop needs to install a helicoil(s) where bolt(s) are stripped out.<br /><br />c/6<br /><br />Hooty
