Hi all, my force 120 won’t shift into reverse when in the water, it just grinds. I’m looking at the shift linkage and adjusted it all the way until linkage hits the back of the slide. There is a lot of extra room in the front of the shifter slide. When I remove the shift cable I can click the shifter on the outboard into forward and neutral but it hits the limit at the end before clicking into gear. Is this a lower unit shift shaft misalignment? I just got this boat and it pisses water really well so I’m wondering if the previous owner dropped the LU to do impeller and didn’t align it properly.
