Hello all, need a little help. I am running a 1998 18' Bayliner with a 120hp force 2 stroke. I was running slow (2000 rpm) for about 1/2 hour. The engine died and has not been able to idle after that. If I throttle up the motor will run but when put back into nuetral it dies right away. It will still go up to WOT without any issues once you are going. I have run this motor for two years now and have never had a proplem with starting and running. Not sure if I should be looking at spark or compression or something else??
any help would be great.
Thanks
Mike
Thanks
Mike
