grininmonkey
- Aug 26, 2008
- 35
I had a much lower compression on the #4 cylinder than the rest which was 135lbs and the rest where very close to 145, after cleaning carbs and everything else I could do on the easy and cheap, I still had poor (warm) idle and cutting off issue. So I decided to pull the cylinder head off.
Attached shows the cylinders which all look to be the same except #4 which appears to have a different bevel, the build up feels like metal, I can not scrape it with my finger nails (solid).
Is it a bad cylinder?
Is it suppose to be shaped different?
The picture with the cylinder that has a "B" engraved is the same on #1,2 and 3, #4 has "EXT" engraged?
Please advise!
Please advise!
