Force 125 Boggs
Mr.
Hi y'all, first time post. I've been having issues with my force 125 since cleaning the carbs. Here's the deal. The boat starts up just fine and idle well. It'll go wot for about a minute then it Boggs way down. I've had the boat for a couple months and it was running ok, had a miss so I figured id clean the carbs. Took off the bowls took off float and valve. The problem is I was not so smart and messed with the float height. Does anyone know how to reset the float height? Thanks
jerryjerry05
Turn the carb upside down.
The float should be even with the bowl flange.
Then right side up, the drop should almost touch the center post.
Wash with Dawn, rinse and blow dry.
NO WD or any lubes install dry.
Hook a piece of hose to the inlet.
Turn it upside down and bow through.
The needle should shut it off.
Then if it keeps bogging thee is another problem.
Like the hoses need replacing or the pump is shot.
Do a comp test just for fun.
