I'm having a problem with the trim ram leaking down. When the motor is tilted up it holds just fine, no drop over the course of several days. I have replaced the seals in the 2 pilot valves, and this corrected the tilt leakdown, and I also replaced the o-ring in the trim cylinder but it still leaks all the way down after a few hours, Any suggestions on where to go from here.<br />Thanks Greg
