Force 125 - Ignition Test - PLEASE REVIEW / COMMENT
Water4Life
Hello All,
What I did: I just finished a test of the ignition system and would like the groups input on my results (see below).
Why I did it: the boat is new to me, bought it with a “non running engine” – after changing the fuel out and cleaning the carbs, she runs! But has a heavy miss in Mid Range RPM. Starts and idles smooth, high end is smooth w/power, but mid range shakes the boat! Side Note: compressions are all good & equal.
What I found: I had been questioning the quality of the spark on #2; it fired on the test plug set at 7/16, but just wasn’t as crisp as 1,3, & 4. I worked from the stator-trigger-module-coil. I found that the high tension lead for #2 gave no resistance/conductivity. Dissected it, and somewhere in its depths it is mostly dead... I am replacing the coil. One other thing that came out of the tests was that the CD Modules are sending ~100v less then test specs to the coils. They are consistent, but low – any thoughts on this?
CD Modules
Range* Range*
n/a 210
To CoilOhmsCommentDVAComment
1n/a 130Test value is low by ~100v, but they are all even - Is the low value a problem?
2n/a 130
3n/a 117
4n/a 113
Thanks All!
jerryjerry05
Your results: if it's a factory stator then they'd be low.
But an aftermarket CDI unit the values are a lot lower.
Try swapping a coil around and see if the bad follows the coil?
Then if it's still a problem? Try swapping the packs.
The connectors can be bad under the shrink wrap.
I replace all of them when doing any work on the ignition system.
