Mark SF Bay
- Sep 22, 2009
- 5
Bayliner Capri: I posted the other day that I had lost power to my instruments. After checking all wiring and finding no problem I pulled the light bulbs from the guages. Every bulb was burn out! Also my fuel and volt guages are toast as well. I replaced the light bulbs. They all worked. So I put the boat in the water. At first I dove at low and medium speed, about 30 minutes. Everything was OK. Then I ran at high speed. Aprox. 30 seconds after appling full power to the engine my instrument lights flashed very bright twice then went out.
All the instruments light are burned out again.
My fish finder which is connected directly to the battery and was on too but it worked normaly and is fine.
What can cause a DC volage spike to the instrument panel?
