force 125 issue
love boat
my 1987 force 125 spits out a decent stream of water at idle but at lets say at 15 knots it only trickles out is that normal it seems to run ok anyone who knows these engines any info would be appreciated
jerryjerry05
Spits out??
​A bit more info??
Does it have a pee tube installed?
Thermostat still in the system?
How old is the impeller?
​Test the overheat system?
​Key on ground the orange lead at the motor, should make the buzzer sound off.
SkiDad
That was normal for my boat if you are refering to the two holes. Change the inpeller if it older than 2 years old.
foodfisher
Water (back) pressure at the exhaust is less under way to allow the exhaust to exit easier. Not so much at idle.
Jiggz
Absolutely normal because of the back pressure created by not moving forward and the main purpose of the two nostrils on the motor leg.
