force 125 no fire
dollysods
hello, i have a force 125 that will not fire at all. new plugs, new and good battery, this thing fired up last year perfect. was winterized. no fire either cylinder. no way both cds are bad. could the stator be dirty and keeping it from firing like on a lawnmower? ne suggestions would be great, because i have already said all that i know about outboards. o yeah bridged out kill switch. please help, its killing me. thanks
Frank Acampora
Re: force 125 no fire
Bridged out kill switch? Kill switch needs to be open. You simply remove the wires and insulate them. If it is an early Force, disconnect the white wire at the engine terminal block and see if you get spark. If you do, then your problem is the work you did on the kill switch.
Jiggz
A simple and cheap in-line spark tester will be very handy for this kind of problems. But as Frank said, the kill switch is normally open. The term "bridge" is always inferred as "permanently connect" so if that's what you're trying to convey, it need to be removed.
