Force 125 Not Starting-No Spark
FirstCast
Hello, first time posting here. I have a 1984 Force 125 with a Bayliner Trophy 1910. The motor ran like a champ for the last four years but so far this year I haven't been able to start it. It will turn over and the starter engages, but I'm not getting spark to any of the spark plugs and it seems like an electrical issue. So far I have tried:
1. Replacing the battery with a new one.
2. Tried starter fluid and confirmed it is is getting fuel.
3. Bought new spark plugs and a spark detector to check for spark.
4. Removed the two white magneto wires and tried to start.
5. Removed the wires from the rectifier and tried to start.
6. Checked all the wires and cleaned the main positive and negative wires.
7. Tried jiggling the throttle to make sure it's in neutral. This doesn't seem to be the problem.
From what I can find on here and other places I think my next move is probably to get a puller tool, remove the flywheel, and check the stator. One guy said that "9 times out of 10 it's the stator". I haven't done much as far as checking voltage/ohms/etc.to the distributors/etc. and I don't have a manual yet. I'm looking for input as to other things to try before removing the flywheel.
Thanks,
Dave
Tassie 1
Download the CDI Troubleshooting guide PDF
scroll through for your motor
jerryjerry05
outboardignitiondotcom. and CDI Ignition has test procedures.
They're probably right about the stator.
Redbarron%%
If I judged by the stack of bad stators in my junk box I would agree with Jerry. Measure the coils like the guide says.
There are two sets of coils the coils that charge the battery through the rectifier / regulator and the coils that generate the ~ 180 volts that charge the capacitors in the ignition. A short in either can upset the magnetic/electric circuits and interfere with the outputs.
FirstCast
I did download the guide from outboardignitiondotcom. I didn't find it very helpful as there are no photos or descriptions. For example "Disconnect kill wire AT THE PACK". Ok, which wire is that exactly?
jerryjerry05
They make these tests for someone who has experience and those people usually have the manual
there to help.
The white wire.
U-tube has a lot of video's that might help.
Pay attention to the tests for the stator.
You can do the basic test for the stator with the flywheel on and a simple multimeter.
Unfortunately!!! the stator can test good and still be bad :(
