Force 125 Propeller Size
roscoe
Re: Force 125 Propeller Size
Without knowing what size you have now, and what your wide open throttle rpm's are, we would be guessing.<br /><br />I guess I would go with the 13. x 17 pitch, and then got up or down from there depending on performance and rpm's, when you order your second/spare prop.
rottenray6402
Ensign
I have that same motor on a 19ft Spectrum Aluminum and the ideal prop for mine is the 17 pitch. I don't know if the Bayliner is that much heavier than my Spectrum but if it is you may need to drop down to a 15 pitch. Hope this helps.
ob12
I have an 84 Bayliner 19' open bow with the force 125 and I have three props for it. I have the 15, 17 and a 19. I prefer the 17 to be honest as it gives the best all around performance for our family setup. It also runs the motor at a lower RPM than the original I had on there, which I think was the 15...
