khoonie
- Jun 22, 2005
- 67
I recently succeeded in adjusting the shift rod on my 1988 force 125 engine. It had been chattering when I tried to put it in reverse, then stopped going into reverse completely. I consulted this forum and learned how to adjust the shift rod; after doing so the engine would shift cleanly into reverse, but it would die and have to be restarted. So I adjusted the idle speed and was able to shift cleanly in and out of reverse as well as forward and the engine idled perfectly and was running better than it ever had. The next time I took it to the lake, it shifted and ran fine at the dock and also ran fine as I pulled away. However, about a minute into my full-throttle run, the engine suddenly stopped dead: the backwash flooded the back of the boat it was so abrupt. I tried restarting and it cranked, but only very, very slowly, as if the battery were dead (it was not). When I got it back home (I had a 5 hp kicker, TG) I put it in gear and tried turning the prop. It would turn, but only with great resistance and it made a slight metal on metal noise when I did so. I am afraid my gears are damaged, but I am not sure. My question is: what should I do first in order to isolate the problem? If anyone can offer some advice here, I would appreciate it very much, as I really don't know where to begin. I thought perhaps there might be some kind of "troubleshooting protocols" based on initial symptoms....
