force 125 tilt/trim
armenk35
does anyone know what might be the problem when i lift my motor up it goes down slowly. and how can i fix it with out changing parts
jerryjerry05
Re: force 125 tilt/trim
What year? It could be you are low on oil.Or itcould be that you need a trim cylinder or tilt cylinder.
When you tilt it all the way it how far down does it go?To the bottom or just part way. I need to know what year and if you have a pic of under the motor at the trim pump and cylinders.Jerry
armenk35
Its A 1987 Sir And It Goes All The Way Down.
