Re: Force 125hp 1986 Odd Noise coming from engine.
My Boat is a 18.5 ft fiberglass center console that is built on a Bayliner Hull. I did ask the guy at the propeller shop about testing if the the hub could be spun and he said that I would definitely know if it is spun by the performance. One thing that I didn't know before is that a propeller shop can re-pitch a propeller. It is expensive, but if you have a Stainless Steel Prop, it would be less than half the cost of buying a new Stainless Steel prop.
I have questioned the accuracy of my tach. I don't know if the signal from the tach has anything to do with the #1 cylinder firing, however I could tell by the sound of the motor that the tach seemed to be behave erratically at times and read higher rpms. For example: I could advance the throttle a little and the tach could move from 4500 to 6200 rpms, the motor would speed up, however it
did not sound like the motor just put on another 1700 rpms like the tach was indicating. Since this boat is new to me, I would adjust the throttle down to keep it cruising at about 5200 rpms because I was afraid of redlining the motor. At 5200 rpms I could maintain a decent plane, however it started falling off of plane just below 4800 rpms. I guess to get a true test is to put the SS 17 pitch prop back on (since I now get a good spark on #1) and check the results.
I can tell you that I tried several times to set the timing on the motor and could never see the marks. I even went as far as taking a black sharpie and coloring the side of the flywheel black and then taking whiteout and coloring the grooves of the timing marks to improve the contrast, however I still could not set the timing because I could not see the marks.
Since swapping the packs, I now have a strong spark on #1. It dawned on me that the timing light probably was not picking up the pulses consistently with a week spark on #1. Just to test my theory, I hooked up my timing light while idling with muffs in the driveway and for the first time I could see the timing marks on the flywheel. I plan on getting out on the water tomorrow and set the timing at WOT.
Frank made an excellent video on setting the timing and checking the carb linkages. Here is his video:
