Hayden2565
- Apr 1, 2022
- 1
Good afternoon all I hope you have some answers to my problem. I have a 1989 force 125hp that will not stay at idle. Every time I put it into neutral it either dies straight away or will run for a few seconds then die. Even if I put it into gear I need to gain a little rpm to keep it running
It runs with no problems when it’s on earmuffs. I can have it in neutral no problem, but the second I take it to the lake it won’t idle.
I’ve rebuilt the carbs and tuned them to factory recommendations. It has a new fuel pump in and and it’s only run on non-ethanol with a 50/1 ratio for the oil to gas
Please help!!!
Please help!!!
