automechanic
- Jul 21, 2010
- 3
I have a 1988/89ish Force 15 hp that does not idle. It is running extremely rich on the lower cylinder, fouling out the plug. Can anyone help? We have been through the carb, all new fuel lines, pulled the exhaust plate-all ports are clear, and pulled the fuel drain plate off-cleaned the screens-cleaned the ports. Can someone tell me if the cover plate with the screens has 2 check valves in it? Looking at the parts diagram it should have, but I can blow both ways through each port. Is this normal? I can start the engine ok, revs up ok, it does smoke excessively, even at full throttle in gear it smokes a lot. The motor also seems to have a lack of power, at top end it feels like a 5hp. If I bring it down to idle, it "pops" and then dies, in gear or out of gear, and after sitting for a while you have to hit the primer before it will restart and then rev it up for a minute before it will run in gear. I am running mid-grade fuel, 50-1 oil ratio.
Any ideas?
Any ideas?
