I have a 1989 force f5 150hp outboard. This engine has treated me well untill this summer. The lower unit lost a cotter pin and I was force to go to the docks in reverse. I then found out that my gasket for the gas door was bad and I contaminated my fuel with water. I have since drained and refilled with fresh fuel but now I have no hole shot power. When I look at my plugs 1 thru 3 are fine but the 4 and 5 are clean as new. While the engine is running fuel is actually spilling out of the lower carb that feeds 4 and 5. I have taken the carb off and check the float and the float appears to be working fine. I have not done a compression check with a guage but the backyard mechanic version of sticking my finger in the plug hole seems to supply the same vacume and pressure across all of the cylinders. I have shop manual for this engine and can't find a similar problem in the troubleshooting section. All plugs seen to have adequate spark, and I have ran a can of engine tune through the carbs to no avail. Any Ideas of a good starting point will be greatly appreciated. I was going to start with rebuilding all of the carbs and see what happens. What is the liklyhood that the reeds have been compromized? Thanks in advance.
