Hi I have a force 1988 125hp that I took out last weekend and it seem to run ok at first with a bit of a shake or miss, as I ran it up to speed it was fine, after a minute it bogged down and seemed to be running on three cyl with the fourth kicking in every so often. I brought it home did a compression check and got 136, 140, 145, 144 also did a check on spark, all coils firing well, and checked flywheel key. Motor has new impellor and new head gasket. Going to do a static timing check today, but I really wont know whats going on until I try it under load again, looking at putting new reeds in as well, carbs seem clean and operating well. Just wondering if anyone has any other ideas or if im headed in the right direction. Thanks
