Force 1988 35hp Outboard User Manual Needed
kelley l.
I inherited a Force outboard. Found a shop manual, but need an owner's manual to understand all the features. Any suggestions?<br /><br />Thanx,<br /><br />Kelley
bill4w
Re: Force 1988 35hp Outboard User Manual Needed
I, also, have the same motor and need a user manual.
roscoe
The owners manual only tells you what plugs to use, to change the gear oil, to mix tc-w3 oil into the gas, and to grease all lubrication points. And don't run the motor out of the water.
Don't know what "features" you need to learn about, but I wouldn't waste too much time looking for one.
The only features you have is trim adjustment, and a choke for starting.
