Force ,1990, 90hp and Sea Foam
1woody1
Does anyone have any experience with using Sea Foam in a higher hp Force outboard? I am wondering about de-carbonizing and using regularily in the gas mix to minimize engine problems over the long haul. I have owned two Force outboards in the past and not had a problem with either but never anything over 50 hp.
BR549
Re: Force ,1990, 90hp and Sea Foam
I have a 1999 90 HP force and started using "Mercury Quickqlean" (sp) in June and noticed a considerable decrease in the carbon buildup. I have heard nothing but good things about Seafoam - but the Mercury product is easier for me to pick up. I use Seafoam in all my air cooled engines - mower, chainsaw, etc with no complaints
dwci97
I have a 90 hp 1990 FORCE and use MARVEL MYSTERY OIL in it per the request of my mechanic. It runs fine with no troubles. I only use a small amount with every fill up of course.
rons boat
Funny, many Mercury manuals called for Sea Foam for all those years. Wonder if the Mercury brand is the same suff with a Mercury label?
roscoe
I use it in my '95 70 hp a couple times a year.<br /><br />I got hooked on it a few years ago when I thought I got bad gas in my van, but I couldn't get it to run right even after 2 fresh tanks of gas. It was running so bad that my mileage had dropped by 25%. <br /><br />Sea Foam cleared it right up. Poured some down the throttle-body, some in the oil, and gas tank- used it a bit stronger for 100 miles, then a full tank at recommended srength. Presto!!
