Re: Force 40 1986 Won't start
That could very much be the problem (ignition)..But before going into that, you need to know for sure it's not fuel-related.<br />You can do this with a simple test. Get an empty spray bottle (fantastic, 409, ect) from the wife, and rinse it out,dry it, and fill it with some mix from your fuel tank.<br />Spray about 4 good squirts directly into the carb's throat. Kick it over. It should sputter or briefly run.<br />If yes, fuel related problem.<br />DO NOT use ether, or "starting fluid".<br /><br />If no, check ignition. These ignition systems are hot hot hot, and can develop arcs as much as 1/2" in air. The problem is, when you test it, you MUST provide a solid connection to ground,to avoid having that hot spark arc INTERNALLY in the coils, CD unit ect, which destroys them.<br />I do this with an old spark plug wire, with small battery clips on both ends.. Remove iether plug. Attach one lead to the plug's thread base,the other to ground. Crank..Observe the spark plug's gap for spark.
