Hi Guys! I decided to start the new thread here.
I bouth the new rig (16 feet Starcraft SS, bowrider) with 40 hp Force on the back. The PO said it was not running. On the motor is says Force by Mercury, so I figure it is 1992-1999, maybe some help on the year?
I have checked the compression and it appers to be in the 135 range on both cylinders. Starter works and turns motort freely. At this point it is not connected to the gas tank and I did not want to start it without asking you guys for the proper procedure.
So I have reinstalled the sparkplugs and reconnected the wires. Now what? Just connect the fuel line and try starting it?
Also one more question, as you see from pictures there is no air filter on the carb - should not there be one?
Aslo just curiosity, is taht Mercury lower end, or Force, Iknow at some point they started putting Merc Lower ends on this motors, but not sure when.
Also, what do you guys think about reliability of this motor?
Thanks a lot!
Thanks a lot!
