My motor will not start sometimes if the electric trim is in a lower position. If you raise the motor up with the electric trim the motor will start. It's not in gear and the battery and connections are good. The times it will not start you can push and hear the choke clicking, but it will not start unless the trim is up.<br /><br />Thanks for any help<br /><br />craig
