Force 5 150hp - bottom 2 cyls not working
randrews45
My mechanic found that the bottom 2 spark plugs do fire but are completely clean while the other plugs show wear and carbon. Suspect bottom carb, what are potential problems that could keep carb from working?
sony2001
Re: Force 5 150hp - bottom 2 cyls not working
Switch the coil wires & see if it runs perfectly. Do you have 3 carbs for 5 cylinders?
sony2001
Read you post further down. Do check the input wires to the bottom CD, they may have been switched accidently. Quicksilver Power Tune is a good decarbonizer. Follow instructions, using less than they say. Don't breath it!!!!! And even put it in thru the spark plug hole for an overnight soak. After a skeg breaks make sure the prop shaft turns true. The skeg itself is not important. :cool:
12Footer
The clean plugs could've been cleaned by steam,indicating water injestion. These engines are notorious for leaking at the port plate gaskets...A cheap enough fix, but time consuming,and critical torque tolerances. Also, could be head gasket.
